Re: New Member with a farmall A
Posted by NNP on September 30, 2014 at 19:04:20 from (66.66.112.196):
In Reply to: New Member with a farmall A posted by gary1213 on September 30, 2014 at 11:55:08:
if you haven't torn it down yet, or even if you have the head off,
pull the pan, fill the water jacket and check for sleeve leaks.
If you are staying low budget, since you have to pull the pistons for the rings, put new rod bearings in, same size that's in there now. (I'd do the mains too, same way)
Plane the oil pump cover and put in a new gasket.
And just a personal preference, others may differ,
if putting new rings on old pistons and sleeves (ball-honed)
I like a cast iron top ring, not chrome.
