Re: farmall m wont start
Posted by SDE on September 30, 2014 at 19:42:15 from (174.124.61.111):
In Reply to: farmall m wont start posted by castle55 on September 30, 2014 at 08:42:06:
Have you tried to pull start the tractor? This would get the engine to roll over a little bit faster and you would have more electrical power for the ignition system, instead of the starter robbing some of the battery power.
I thought the proper way to adjust the valves was to put the engine at TDC for cylinder #1. Adjust both valves on #1 and one valve in cylinders 2 and three, and then rotate the engine one revolution to get #4 to TDC and adjust the remaining valves.
Your tractor started to spit and sputter while plowing snow. Maybe that is the problem you are still looking for.
SDE
  Upload Photo  Select Gallery Photo  Attach Serial No List
