Re: Re: Re: spark plug gap after electronoc ignition
Posted by H MN on January 04, 2001 at 07:13:51 from (63.253.192.249):
In Reply to: Re: Re: spark plug gap after electronoc ignition posted by IHank on January 03, 2001 at 23:23:20:
IHank: You forgot to mention that a longer firing time wears down the electrodes of the plug at a faster rate.(like welding) I had one system, many years ago, that fired a wider gap with a shorter time duration but it also fired the plug twice. The second spark was just enough later to allow approx another degree of rotation of the crank allowing new mixture to flow past the plug incase the first spark didn't start the fire.. interesting stuff for me years ago but now I just like it if the dern thing starts and moves forward..;) harvey
Post A Followup
: Re: Re: Re: Re: spark plug gap after electronoc ignition
