Posted by mkirsch on October 02, 2014 at 10:44:54 from (72.45.143.81):
In Reply to: Ethanol based fuel posted by mikesbailey on September 27, 2014 at 16:31:55:
Frankly I don't think now is much different from the 1930's.
The ethanol is causing the problems, but INDIRECTLY.
I've placed rubber fuel hoses and viton carburetor needles in 95% ethanol (i.e. "Everclear" liquor) and noticed no ill effects. You'd think if 10% were causing havoc, 95% would cause it 9.5 times as fast, wouldn't you?
The REAL problem is the crap the fuel companies are blending in with the ethanol. Ethanol has a huge effect on the octane levels when mixed with gasoline, which means that fuel companies can use lower-grade fuel in the blend.
That lower grade fuel has more volatile compounds in it, compounds which I'm pretty sure are used in the manufacture of INDUSTRIAL SOLVENTS, that would definitely melt rubber and plastics.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
