Re: Re: IH 460 power steering
Posted by T_Bone on January 04, 2001 at 07:55:31 from (207.254.53.137):
In Reply to: Re: IH 460 power steering posted by Duane P on January 03, 2001 at 23:38:20:
Hi Duane, sounds like the relief valve is stuck open and the fluid flow is just looping with no pressure going to the PS motor. You really need a pressure gauge to confirm where the problem is, about $50 with all the fittings & hose. Try Northern Tools. You should be able to take out the filler plug and watch return flow. Make sure your filter is clean and the oil doesn't have water in it. Let the tractor sit over night, then pull the drain plug and see if water doesn't come out first. Of course it has to be above freezing temperature.
T_Bone
Post A Followup
: Re: Re: Re: IH 460 power steering
