Re: farmall A or international AI
Posted by gene bender on October 02, 2014 at 16:33:29 from (67.55.226.121):
In Reply to: farmall A or international AI posted by 40internationalAI on October 02, 2014 at 10:49:18:
You need to find the cast codes also what is the serial# on the block and part# like other posts have said your tractor could very well be one that has had many changes over the yrs. Where is the regulator located thats another clue does it have a hole in the hood not used. Shutters were an option on any tractor built so there is no big deal about the shutters. If the engine has not been changed the serial# woill have FAA1 also.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
