Re: Questions about a 1941 Farmall H I recently acquired.
Posted by D Slater on October 02, 2014 at 17:10:25 from (184.14.160.167):
In Reply to: Questions about a 1941 Farmall H I recently acquired. posted by topcat5150 on October 02, 2014 at 10:47:43:
Rockford 10 inch clutch. Pressure plates were made to be repaired. Depends on condition and your skill.
Front wheel on right was the most common for 41 and probably what came on the tractor since it looks like a K on the date code.
Probably has a aftermarket manifold, they had slotted holes to fit H through 350 carburetors.
To remove the engine crank the ratchet part in the bolster needs freed. Besides removing the cotter pin the thin tin sleeve under the spring needs to slide to remove the pin under it to remove the cranking shaft. Also has a retaining ring to keep the tin from coming off the crank ratchet.
When like yours it takes time and patients to get off without damage. Sometimes that doesn't work. To much heat will mess up the spring and tin sleeve if needing to save them.
On the seals find the IH numbers and a cross over chart.
  Upload Photo  Select Gallery Photo  Attach Serial No List
