Re: Questions about a 1941 Farmall H I recently acquired.
Posted by eastsider on October 02, 2014 at 17:19:22 from (24.111.75.41):
In Reply to: Questions about a 1941 Farmall H I recently acquired. posted by topcat5150 on October 02, 2014 at 10:47:43:
You will want to get a rebuilt clutch and pressure plate, and
new pilot bearing for the flywheel.
The carb question has been covered.
The advice to get a new pedestal with matching hubs is good
advice...not too hard to find. I have one myself if you would
like it...reasonable. Located in Northern Minnesota.
As for moving the hand crank setup, taking out the cotter key
only lets it slide backwards a bit...not to remove it. If you look
closely, there is a stepped collar on the shaft end...it is very
thin metal and you need to heat it carefully to slide it forward in
order to drive out a straight pin holding the assembly together.
Once that is apart, you can pull the shaft and remove the rest.
Get a parts manual or look up the diagrams on line to see a
diagram.
  Upload Photo  Select Gallery Photo  Attach Serial No List
