I agree, just get a reman'd clutch and pressure plate, preferably from Case-IH dealer, then do not try to re-adjust them, just stick them in. Clutch should have an oil flinger plate, it should go on the forward side. Be aware, that taper-bolt wavy 4-bolt plate at the end of the drive shaft, will go in either way; install it with the most space inside it, not with the closest fit inside it. [If that makes sense...] If you install if with the least amount of space inside, and you actually can do it, the drive shaft will not go inside the pilot bearing, and it'll whip around and destroy things. LOng sad story...
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
