Posted by MikeJM on October 03, 2014 at 17:19:17 from (69.248.215.112):
In Reply to: rotary tiller for SA posted by rray on October 03, 2014 at 11:49:45:
I've seen literature for the cub rotovator. Part of the install package was a gear reduction unit that went between the left final drive and trans case. Talk about a bunch of extra work for the diff.
The hydra creeper drove trough the pto while the clutch was held in. Lots of wear and tear on the throw out bearing and thrust main. Couldn't do pto work as it was meant to transplant at very slow speeds.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
