Re: Farmall 460D starter issue
Posted by Owen Aaland on October 04, 2014 at 00:46:51 from (216.47.34.49):
In Reply to: Farmall 460D starter issue posted by John Athey on October 03, 2014 at 22:37:49:
It could be (1) low voltage due to a poor connection in the key switch, push button or wiring, (2) a worn contact in the solenoid, or (3) worn brushes.
A simple thing to try, and probably the most common cause, is to remove the battery cable from the starter solenoid and back off the inner nut until you can push the stud in about 1/4". Rotate the stud 180° and reinstall. That will give a worn stud stud a new contact surface providing it has not been rotated before.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
