Re: IH model H, won't start
Posted by NNP on October 04, 2014 at 04:35:01 from (66.66.112.196):
In Reply to: IH model H, won't start posted by james06 on October 02, 2014 at 18:06:57:
stuck engine on a tractor that has been sitting,
means a completely stopped up carb...with rust..
Like the other posters have said, gotta try again.
Just soaking in carb cleaner won't do it with rust.
gotta break out the wires, needles, and probes.
With your symptoms, with the supply and bowl drain showing flow,
first suspect like mentioned is the main nozzle, its well, and passages. usually a rusted disaster area.
(careful here if it's a threaded in nozzle, they break easily when rusted in)
And depending on which carb design, a main jet and its passage/needle at the bottom of a carb bowl is sure to be full of rust.
