Re: Super A steering slop solutions
Posted by Daniel on January 04, 2001 at 10:10:59 from (206.74.50.21):
In Reply to: Super A steering slop solutions posted by BIG on January 04, 2001 at 08:13:37:
The Super A steering box is always a problem area. The box is not adjustable, however, there is a large nut on the bottom that may need tightening. I believe it is 1 5/8". If that doesn't tighten it up you will have to rebuild the box. The top bearing in mine was shot causing the sector shaft to flop back and forth causing the play. There are two seals and two bushings and two bearings and a gasket in there to replace.
As for the tie rod ends, do you have the automotive style or the curved ones with the ball on top?
Post A Followup
: Re: Re: Super A steering slop solutions
