Re: Re: Re: Re: Re: 12v generator on H
Posted by Bob M on January 04, 2001 at 10:56:31 from (192.232.119.194):
In Reply to: Re: Re: Re: Re: 12v generator on H posted by W.W. on January 04, 2001 at 08:47:11:
WW - If the lights and motor work with the wire to the "L" terminal on the regulator disconnected, the wiring is screwed up somewhere. (Ordinarily the L wire provides power for the lights and ignition.) This could also account for the ammeter discharge indication with the lights on and the motor running. Does the ammeter show a discharge when you turn the lights on with the motor stopped?
Post A Followup
: Re: Re: Re: Re: Re: Re: 12v generator on H
