Posted by D Slater on October 05, 2014 at 16:31:36 from (184.14.160.167):
In Reply to: Super c distributor posted by Joshua Rod on October 05, 2014 at 15:41:56:
If it turned okay before the gear change you ended up with no shaft endplay after putting the pin in the replacement gear. Or let the shaft push toward the point plate and mess the weight guard up. Also find them that someone used to long of screw in the condenser or point contact mount and mess the guard or other things under the breaker plate. If you have end play, remove points and the terminal post from the distributor. Then the 2 cap clip screws and one other from the side of the distributor. Lift the breaker plate out then check guard, springs, weights and the weight pins. Shaft can be removed from the body after the drive gear is removed.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
