Re: How to remove seal on lift-all
Posted by D Slater on October 07, 2014 at 05:27:43 from (184.14.184.113):
In Reply to: How to remove seal on lift-all posted by unioncreek on October 06, 2014 at 21:16:53:
third party image
Unless you make up a tool to use a impact wrench trying several starts of the wrench. Or sharp blows from a Hammer and drift punch you need to unbolt the complete plate from the reservoir unit.
Then put something that wont damage the gears up through the suction hole that points to the bottom.
Even if the first two methods are tried the driven dog may not come loose that way unless lucky.
Drive dog you want to remove is on the other end of the right gear shaft in picture. Square looking part of the casting below the gears is the opening that gears can be jammed through.
  Upload Photo  Select Gallery Photo  Attach Serial No List
