Re: Farmall M going from 6 volt generator to 12 volt generator
Posted by John T on October 07, 2014 at 07:47:15 from (216.249.72.121):
In Reply to: Farmall M going from 6 volt generator to 12 volt generator posted by Robert in KY on October 06, 2014 at 19:40:02:
Sparky Jim has you well covered on wiring etc. I will just add that just because you're going from a 6 to a 12 volt Generator THERES NO ACTUAL NEED TO CHANGE TO NEGATIVE GROUND although no harm either. Its just that if you stay at Pos ground you don't have to swap ammeter or ignition coil leads. If its a coil distributor ignition however (not a Mag) you need to EITHER get a 12 volt coil or else add a series voltage dropping (12 down to 6) ballast resistor if you use the old 6 volt coil. As Jim noted your new 12 volt voltage regulator needs to be suitable fro whichever ground you choose. One advantage of going to Neg ground is that a lot of 12 volt tractors are configured that way and it makes for easier jumping for an inexperienced operator. She will crank over much faster if you go to 12 volts.
We may tell you what is what but we rarely slap folks on here lol
John T
  Upload Photo  Select Gallery Photo  Attach Serial No List
