Re: Farmall md rod and main bearings
Posted by caterpillar guy on October 07, 2014 at 08:05:40 from (75.134.164.203):
In Reply to: Farmall md rod and main bearings posted by eddie v on October 04, 2014 at 13:15:42:
the cam bearings will affect the oil pressure as much as the crank bearings will. Or the pump may be the culprit.
  Upload Photo  Select Gallery Photo  Attach Serial No List
