Re: Hey TractorVet and DeltaRed!
Posted by Heat Houser on October 07, 2014 at 08:37:12 from (69.66.35.73):
In Reply to: Hey TractorVet and DeltaRed! posted by IAtractorKid on October 07, 2014 at 07:52:43:
Any oil rated as CJ-4 by API (American Petroleum Institute)is a low ash oil. (I use 15W-40 Shell Rotella T in my 560 which is CJ-4 rated)
Please don't tell my 560 that it needs 91 octane as I run it on Gasohol at 87 octane.
If and when you do a valve job, be sure to readjust the valve lash after 25 engine hrs or so. They seat in, tighten up, and burn. When I was a kid, the neighbor would do a valve job every year due to lack of checking lash. This was when we had leaded gas and he used IH Low Ash.
  Upload Photo  Select Gallery Photo  Attach Serial No List
