Re: How to remove seal on lift-all
Posted by Dave S. on October 07, 2014 at 05:06:08 from (208.92.170.70):
In Reply to: How to remove seal on lift-all posted by unioncreek on October 06, 2014 at 21:16:53:
Use a piece of flat metal 1/8" x 3/4" x 6"( it does not have to be brass) to fit teeth in pump evenly( do not use a round rod it will put to much pressure in one place and damage teeth) Insert flat metal into oil intake of pump. You can also try welding a piece of key stock (that fits the slot on the pump drive) to a socket and use a !/2" impact to try to remove drive without taking pump out of reservoir.
Sometimes the drive will come off by using a hammer and heavy punch to break them loose. The drive screws on and is right hand threads.
