Can't say as I've seen tractor vet post in a while, so not sure if he'll weigh in on this, but his missives/diatribes/rants/advice on this specific subject is here on this forum dozens of times and easily located through the search feature.
Vet-recommended octane is 93 as marked on the pump at the gas station. None of this, "Manual says Research method and pump is an average so if this that and the other thing hold true, 87 octane pump gas is the same as 93 by the Research method."
Right or wrong, a few gallons of 93 is a heck of a lot cheaper than taking a chance on melting a piston and ending up with a costly engine rebuild.
You're spot on with the IH low ash oil.
One other thing I remember is that you need to set the timing with a quality timing light.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
