Re: '34 F12 Starting/Timing Issue
Posted by Tom Fleming on October 07, 2014 at 15:49:04 from (67.20.239.72):
In Reply to: '34 F12 Starting/Timing Issue posted by DC Snider on October 06, 2014 at 09:27:49:
you are on the right track. Remember, the carb fuel bowl MUST be full of fuel for these to run. The IHC #10 carb (which I believe to be the right number) can be VERY cantankerous. However, when they are right, they will fire right up and run......and run well.
make sure the fuel bowl is full. There should be a drain on it. crack the stopcock valve open and see if you have fuel. if you are using a gravity feed, if it is dry, the float needle valve may be stuck shut. If you have fuel, then it should fire and run.
