Re: TDC
Posted by Janicholson on October 07, 2014 at 18:35:36 from (74.60.94.18):
In Reply to: TDC posted by jsr8011 on October 07, 2014 at 14:36:27:
Heat the straw at about 2 inches with a lighter (not on fire) and bend it so it will feel the piston, but have a handle. Remember it can be on TDC compression(good) or TDC exhaust/intake(bad). If the valve cover is off, both valves closed Compression. if VC is on. the rotor should point to #1 plug wire. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
