Re: Different style ballast resistor. Will this work?
Posted by Bob on October 07, 2014 at 20:41:22 from (64.255.159.192):
In Reply to: Re: Different style ballast resistor. Will this work? posted by MNGB on October 06, 2014 at 16:22:04:
Resistors are now rated by VOLTS???
WHY not tell the OP that the resistor be has is for a GOAT from the 70's or 80's and the resistance is quite a bit different between the two resistors contained in the one ceramic block?
  Upload Photo  Select Gallery Photo  Attach Serial No List
