Re: Siezed Super WDR-9
Posted by kub6040 on October 07, 2014 at 23:34:19 from (184.169.242.158):
In Reply to: Re: Siezed Super WDR-9 posted by W-400 Chris on October 07, 2014 at 19:56:54:
I use acetone and atf ,mostly acetone , my thought is you want it to go by the rings so thinner is better , wait 20 minutes and take half of a pto shaft "the part between tractor and implement" put on tractor pto with joint positioned so that it locks and use it as a pry bar with pto engaged
  Upload Photo  Select Gallery Photo  Attach Serial No List
