Re: Best tractor for loader work
Posted by Siefring Red Farmer on October 08, 2014 at 06:17:00 from (144.191.148.6):
In Reply to: Best tractor for loader work posted by flhr62 on October 07, 2014 at 11:17:05:
684. No doubter. The 2250 is a great loader, but check a few things. The support on the front is notorious for rusting out a bit, where the support and the front forks meet. I have one and have welded this joint a couple of times. Also, check if it was welded and if so, see if the front forks are sprung from it. The heat from welding will pull the forks.
And then, also check the pins and bushings for wear and if they are greased regularly just like any other loader.
