Re: Siezed Super WDR-9
Posted by Ron in Nebr on October 08, 2014 at 13:08:01 from (70.198.37.203):
In Reply to: Siezed Super WDR-9 posted by W-400 Chris on October 07, 2014 at 18:40:45:
In addition to what was posted below, when you pull the starter off and pry against the ring gear teeth with a BIG prybar(I used a 5ft long spud bar), pry it opposite of normal engine rotation.
An old mechanic told me this trick and using it along with a few cans of penetrating oil shot through the plug holes I had my 650D unstuck the first day I had it home.
  Upload Photo  Select Gallery Photo  Attach Serial No List
