H transmission problem solved FYI
Posted by Jeff on January 04, 2001 at 14:10:01 from (12.2.88.88):
Last Sept I mentioned my transmission made grinding noises when in 4th and when I pushed in the clutch after driving in 2nd. I discovered that the roller bearing, p/n 43356DA, was destroyed. I replaced it and all is fine now. I thought I'd pass this on for anyone having a similar problem. I was able to replace it through the belt pulley opening and the driving shaft bearing cage opening without having to remove the rear frame cover.
Post A Followup
: Re: H transmission problem solved FYI
