Re: Siezed Super WDR-9
Posted by W-400 Chris on October 08, 2014 at 19:10:39 from (209.121.225.197):
In Reply to: Siezed Super WDR-9 posted by W-400 Chris on October 07, 2014 at 18:40:45:
Thank you very much for your help! I Pulled the valve cover today so I could open the exhaust valves and get more ATF and Howes diesel fuel conditioner into the cylinders, I'll let it works it's Magic for a bit maybe try pulling the starter off and barring it over, I've got a 15 hour drive ahead of me do if nothing else I may leave the chains a bit loose and let it rock in high gear I've heard this may work also. It's all learning for me so I guess we'll see.
  Upload Photo  Select Gallery Photo  Attach Serial No List
