Posted by dewy on October 09, 2014 at 04:05:31 from (72.152.228.239):
on the tree the throttle is at half throttle at idle,if i go below half throttle it dies..does go to full trottle...i have set govwith throttle wide open an lined up carb linkage with gov..i have looked at every thing in carte carb except low idle screw in bottom of carband bleed nozzle could not get out,,how are they to be set and any tips on getting them out..also idle screw does nothing..made sure hole was clear into carb throat....thanks dewy
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
