Posted by mkirsch on October 09, 2014 at 05:16:24 from (72.45.143.81):
In Reply to: 1951 Farmall C posted by vet119 on October 08, 2014 at 15:03:59:
The Volts and Amps thing is described by Ohm's Law, which states that there is a mathematical relationship between Volts, Amps, and Load.
Ohm's Law: Volts = Amps X Load
If you keep the Load the same, and double the Volts, in order to make the equation work, the Amps have to double. If you measure it in real life, you will see that it works out.
So long as you don't crank and crank and crank and crank and crank and crank and crank and crank and crank and crank and crank on the engine with 12V, the starter will hold up just fine. Fix the tractor so it starts easily.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
