Re: W9 clutch
Posted by used red mn on October 09, 2014 at 10:06:36 from (166.137.101.173):
In Reply to: W9 clutch posted by Howard Junkin on October 07, 2014 at 14:29:48:
Some may cringe when I say this but in this case I would
recommend a little clutch abuse. Once you have it loose put
the tractor in road gear and set the throttle wide open. Then
slowly engage the clutch until the tractor is up to road speed.
Two or three treatments like this should shine up the surfaces.
If not pulling apart will be your only option. I do wonder how
long it sets between uses and weather it is shedded or not.
  Upload Photo  Select Gallery Photo  Attach Serial No List
