Re: Super A steering slop solutions
Posted by Haas on January 04, 2001 at 14:27:50 from (129.37.117.248):
In Reply to: Super A steering slop solutions posted by BIG on January 04, 2001 at 08:13:37:
David A's comments are right on the money. I suspect if you replace the bearings, the play will improve substantially. Just the worm gear bearing may help a lot. Also check the nut under the bottom that holds on the arm that goes to the tie rods. Sometimes that nut gets loose and lets the arm flop around causing play.
Post A Followup
: Re: Re: Super A steering slop solutions
