DT436 blowby questions
Posted by Dave from central MN on October 09, 2014 at 18:51:21 from (198.98.195.248):
Ok, have this 1460, which I got pretty cheap
and is doing a great job, starts below feezing
with out either or being plugged in. Has plenty
of power and exhaust is pretty clear except for
when I first crack the throttle, or she eats
ALOT of really tough beans. The issue is oil
coming out of the blowby tube. I wold say it
drips out about a quart every 2 hours, maybe
even a bit more. The vent on this engine is up
on the valve cover, and runs down the side. Is
there any other reaon this could be being
caused as the engine sure as heck seems like
she is tight otherwise. Should I be using
straight 30 weight oil, not 15-40? Cold start
oil pressure pretty much pegs the gauge, once
its been running quite a while it stall has
great oil pressure, even at a hot idle. I did
notice a little bit of antifreeze up in the
engine around one of the injectors.. is not
using any noticable amount of coolant. Any
advice, thoughts, knowledge?
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
