Posted by Janicholson on October 10, 2014 at 13:32:41 from (199.17.6.26):
In Reply to: Steering Cup positions posted by henhawk1969 on October 10, 2014 at 11:30:02:
Steering cups is a bit of an unknown. If you refer to the adjustable ball joint, or tie rod end, then they can be serviced. Usually the ball is out of round and it might be possible to grind it spherical with care (usually not). The disks can be replaced if they are missing. 318309 and lower Serial numbers have adjustable rod ends on both. If above that # the rod ends are not adjustable. The non adjustable ends appear to be available. You will need to have the others repaired, or components made. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
