Posted by D Slater on October 11, 2014 at 11:34:32 from (184.14.184.128):
In Reply to: Re: W9 info posted by D Slater on October 10, 2014 at 13:58:50:
Was to lazy to double check when I posted the hole size, so that parts a mistake. If you want 40 degree advance at the crankshaft the slotted hole is .355 to .357 long. Gas start diesel shaft is like the small hole in the picture. Extra hole is a modified shaft. Other shaft is for one without advance. Small hole needs to be made longer to the left side in the picture. Then get a set of 358106R91 advance springs. Advance limit holes were drilled round up to around 30 degrees advance then slotted when more was used.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
