You have a very good and handy toy there!! Do not be sad but you do have a problem. Shove the seat all the way back and check your oil level. Dip stick unscrews and looks like a pipe plug. It will show you the oil level. Use Hi-tran oil.If you still have slow action you will need to FIX it!! Most of your trouble is the bronze screen that filters you hydraulic oil. It has a very fine mesh and is a total Bit*** to get to. The seat and the cast iron top need to be removed. VERY heavy and a bunch of bolts and guide pins too. The guys on here have covered this many times and can tell you how to do it. Chain hoist brass hammer screw drivers etc. Also an added alert!!!!!!!!! If you have power stearing on this tractor for hevens sake check the oil level in the stearing unit. On the left side of the tractor sqwat down and look just in front of the battery where your throttle linkage is. At the rear of the power unit you will see a 1/2 or 9/16 pipe plug. Pour a little 90 weight in there!!!! If no oil it chews up the steering rack. BBBIIIGGGG bucks. Lt us know! Jeffcat
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
