Re: 6v generator question
Posted by Owen Aaland on October 13, 2014 at 00:30:49 from (216.47.34.49):
In Reply to: 6v generator question posted by boler76 on October 12, 2014 at 15:16:27:
boler76 said: (quoted from post at 18:16:27 10/12/14) does anyone know what the field coil total resistance in ohms should be for a 6v 3 brush externally grounded generator ? Thanks
We need to know the model number to be more precise but here are the specs for a couple different ones used on an H. The resistance is not give, just the amperage draw so you will have to calculate the ohms.
# 1100501 Spec # 1778; 10 - 13 amps; 7 volts; field coil draw 2.5 - 2.72 amps.
# 1101355 Spec # 1651; 13 - 16 amps; 7 volts; field coil draw 3.5 - 4.5 amps.
This post was edited by Owen Aaland at 06:31:39 10/13/14.
