Re: Just aquired Farmall 460 and have questions
Posted by Orrin on October 13, 2014 at 10:03:02 from (184.61.135.254):
In Reply to: Just aquired Farmall 460 and have questions posted by RC Brooks on October 13, 2014 at 09:40:50:
Thanks, I had not thought about using cheaper hydraulic oil to help purge the system. Good idea as long as the TA will handle it. We won't be doing any heavy draft work with it though.
Stearing is awfully loose. I checked the shafts and u-joints. It appears to be in the stearing gear. I will have to do research to see if that can be tightened up.
