In a word, NO. 1. Check inside the distributor to see if the condensor wire is touching ground.
2. Remove the coil wire from the cap center hole and hold it about a 1/4" from metal ground. With the switch on and points closed, use your fingernail to "flick" the points open several times. You should observe a bright blue spark from the coil wire air gap. Many times the points need cleaning to make a good connection.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
