Re: Starting my M
Posted by rustred on October 14, 2014 at 11:27:39 from (74.214.153.210):
In Reply to: Starting my M posted by Dr. Bert on October 14, 2014 at 10:45:38:
what happens if you pull the choke first then crank?
but from what i have experienced with these 6 volts is you need the fattest batt. cables and that makes a big difference on cranking. also the starter push switch must be in good condition, as there is two brass connections inside that either are worn or corroded. the one can be turned around also if it is worn.
  Upload Photo  Select Gallery Photo  Attach Serial No List
