Re: M hand crank removal
Posted by Bob M on October 14, 2014 at 12:17:50 from (67.240.162.4):
In Reply to: Re: M hand crank removal posted by CoDave on October 14, 2014 at 12:00:49:
Yes - you can safely support the front end of the tractor at the clutch housing. Just be sure to securely chock the rear tires so it cannot move while jacking, etc.
The bolster will slide out easily after disconnecting the radiator hoses, removing the steering shaft then removing the bolts thru the side rails. Loosening each of the motor mount bolts a couple turns can be helpful.
Be aware the bolster assembly is VERY heavy and top heavy. For safety use a loader, engine hoist or similar to handle it.
  Upload Photo  Select Gallery Photo  Attach Serial No List
