Re: farmall 340 trans oil leak
Posted by D Slater on October 15, 2014 at 05:22:17 from (184.14.184.128):
In Reply to: farmall 340 trans oil leak posted by Ramp;W on October 14, 2014 at 19:10:01:
If the hole is in the cast part of the housing and not in a steel plate, its probably oil leaking into the T/A clutch compartment. IPTO drive shaft with gear seal can leak into there, along with the T/A carrier or sun shaft seal.
First one requires a split at rear of engine to fix and the most common leak area the second place requires the center housing being removed from the tractor.
  Upload Photo  Select Gallery Photo  Attach Serial No List
