Re: Main fuel adjustment screw. Farmall 300
Posted by rustyfarmall on October 15, 2014 at 07:09:38 from (208.126.186.41):
In Reply to: Main fuel adjustment screw. Farmall 300 posted by farmallmaniac on October 14, 2014 at 14:37:55:
You need to understand just HOW a sediment bowl works. The screen sets at the top of the bowl. If the screen is original, or a genuine replacement, it will be made of nylon. Not brass. The fuel comes out of the tank, into the sediment bowl, and THEN it has to pass through the screen and then into the fuel line. IF there is rust in the fuel tank, that rust WILL go into the sediment bowl where it will settle out of the gas and collect in the sediment bowl. THAT is what a sediment bowl DOES. The screen at the top of the bowl will catch whatever rust did not have time to settle, thus allowing only clean fuel to enter the fuel line.
