Also, that isn't the hydraulic pump. That is the "Touch Control" hydraulic resivoir which houses the piston and control valves. If you follow the hydraulic lines from the TC Resivior, you'll find the hydraulic pump on the engine block. It is squarish and made of aluminum.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
