Posted by farmallhal on October 15, 2014 at 07:44:11 from (76.2.172.19):
In Reply to: super c oils posted by bass on October 15, 2014 at 07:17:56:
Yes, it is covered in the Operators Manual under lubrication. For the engine it states 10W, 20W or 30W depending on the air temperature. 20W covering the temperature range of 32F to 80F. Takes 5 quarts plus another 7/8 pints for the air cleaner oil cup. A lot of folks on this forum including me use 15W-40 Shell Rotella year around in our older generation IH engines which is far superior to oils available when the tractor was produced. For the transmission it calls out 5 gallons of SAE 90 weight unless the temperature is below 32F in which case 80 weight might be used. For the touch control hydraulic system it call for 6 3/4 pints of Touch Control Fluid which Hy-Tran or equivalent can be used since it is no longer produced or available. Hope this is what you are needing, Hal.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
