Re: Farmall A LoBoy
Posted by Buddy Woodson on October 15, 2014 at 13:22:47 from (76.22.181.65):
In Reply to: Re: Farmall A LoBoy posted by Redturbo on October 15, 2014 at 11:11:34:
third party image
I wanted a single engine to go with my double and triple A's
and something that IH did not offer. It's 8" lower and 8" shorter
than a production A. Finals are rotated 90 degrees forward
and I took 8" out of the front spindles. Had to drill and tap
some new holes to reattach the finals since the holes are not
symmetrical. I also cut new paths for the brake rods to keep
them in their original position and not sticking out of the top.
Had to move the fenders forward and rework the drawbar.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
