Re: 350 UTILITY
Posted by D Slater on October 15, 2014 at 17:00:23 from (184.14.184.128):
In Reply to: 350 UTILITY posted by S2710 on October 15, 2014 at 13:48:48:
Farmall blocks have all 3/8 diameter bolts retaining the front engine cover. Utility blocks have some 1/2 diameter bolt holes in the block and front cover to help with front bolster support. If you really want to use a H block you may be able to make the bolt holes larger and tap threads where the 1/2 inch bolts go.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
