Re: Re: F12 headgasket leak
Posted by DONNIE REDDING on January 04, 2001 at 17:55:31 from (216.207.62.132):
In Reply to: Re: F12 headgasket leak posted by RB on January 02, 2001 at 12:53:26:
IF THE HEAD GASKET CONTINUES TO LEAK. CHASE OUT THE THREAD IN THE BLOCK BE CAREFUL TO USE THE RIGHT SIZE TAP OR IF IT HAS STUDS THEN CHASE THEM WITH A DIE. THE REASON THIS NEEDS TO BE DONE IS SO THE TORQUE WRENCH WILL GIVE AN ACCURATE READING. CARRY THE HEAD TO YOUR LOCAL MACHINE SHOP AND HAVE IT MAGNA FLUXED AND CHECKED FOR WARPAGE. HOPE THIS WILL HELP
Post A Followup
: Re: Re: Re: F12 headgasket leak
