Re: IH 340 Utility Tractor radiator drain
Posted by farmallhal on October 16, 2014 at 06:24:42 from (76.2.172.19):
In Reply to: Re: IH 340 Utility Tractor radiator drain posted by homebre973 on October 15, 2014 at 19:44:40:
I can only relate to my experience on removing and reinstalling the radiator on a Farmall 240 but believe your tractor is very similar. An additional pair of hands and a helper are a big help when reinstalling the radiator for certain. Take notes or photos of the various supports for the radiator and the front grille items as they are removed on the stack-up of the various items and where the various hardware items install as they are removed. You might find placing labels on certain parts and placing the hardware items in small plastic sandwich bags labeled as to where they reinstall might be beneficial. A parts catalog or diagrams on the CaseIH site will prove very beneficial. It is not a big job at all to replace everything up front while the radiator is off the tractor. When reinstalling the radiator the extra pairs of hands are needed to make the hose connections (make sure the clamps are on the hoses first and rotated to a position so you can get too later to tighten them up) while the other person is supporting the radiator. Even though the radiator remove and replace is straight forward and not at all difficult it is not something I would want to do very often so I refreshed everything while I had it removed.
From what you indicated about the overheating issue you are experiencing it seems a radiator removal, clean, repair and reinstallation are also required at this point to resolve your combination of issues. Hope you find this information helpful in the solution to your situation, Hal.
  Upload Photo  Select Gallery Photo  Attach Serial No List
